Fused Distribution blocks...comparing fuse types.
which distribution block would you want?
  • 5025 w/ blade fuses
    Votes: 16 94.1%
  • 5015 w/ glass fuses
    Votes: 1 5.9%
  • Total voters
    17
asteffes
I agree that's it nice to find everything in one place. You can buy zip-cord so that when you run a positive wire, you also run a negative for ground. Then you never have to hunt around later on for that random ground screw. Also, you ensure everything is equally well-grounded to the same point on the chassis. Run a single fat 10 or 8 gauge wire from your wiring block to a big chassis bolt and you're set.
Goldenbora
