GEARS..??
justcuz
I would think you could find a 6 lug 14 bolt semi float somewhere in your neck of the woods. I put one in my 1993 Suburban. Mine came with 3.73 gears so I just bolted it in, even used the old 10 bolt parking brake cables. Needs a conversion U joint or a 3/4 ton driveshaft.
They come out of 88-98 Chevy or GMC pickups with the F44 option I believe. Mine came out of a K2500 light duty extra cab short bed, 3/4 ton springs and torsion bars and the 6 lug 14 bolt rear axle.
I have seen K1500 trucks with this axle though.
This way you can swap out all 1500 front and rear differentials from the wrecking yard to match, probably cheaper than gears.
thatboykg
@justcuz yea thats what i did 1st. No luck. I used to have one those light dutys as a work truck 12 years ago, havent seen another one since. Lol. But 4 Wheel Parts up in dallas is goin to do the swap.. parts, labor, and 2 year warranty is going to run $1750.
flipstick
