BEG
My '00 suffered a failed tensioner which led to a broken cam dowel pin and what I assume to be unspeakable damage to the valves. I need to fix it fast and cheap so I'm considering just swapping a used running engine in for the time being. There are plenty of Montero and Montero Sport 3.5 engines available but the Diamante engines are even more plentiful and a lot cheaper.
From what I've read, the Diamante 6g74 has a forged bottom end and slightly more horsepower with peak torque coming in later in the RPM range. However, the cam profiles are the same. The difference is in the cam sprockets and intake. So the real challenge would be going from a FWD application to RWD. Has anyone used a Diamante block in a Montero? What kind of issues should I expect? I know a straight swap from another Montero would be easiest but the price difference is about half for a Diamante engine, so I'd really like to see if it can be made to work. Thanks.
