Hello Everyone,
my 2003 montero has a little fuel leak. I took off the fuel tank cover and found what looks like a drain plug on the bottom of the gas tank leaking. Is this a drain plug and does anyone have a part number for it? Is the replacement has easy as a oil drain plug, or are there special considerations due to a pressurized system? Is it common for this plug to leak?
EDIT1: it is indeed a fuel tank drain plug, it appears whatever washer was used has started to breakdown causing the leak...i gave a very slight tighten on the bolt and it looks like it has temporarily halted the leak. I found the part number for the plug (1715A135) and it fits on multiple mitsu makes and models, none of my local mitsu dealerships carry it and its not available anywhere close, i suppose i could reuse the old bolt and just replace the washer with a copper one? but i was hoping to do a quick take the old one out put the new one in without draining the fuel
Thanks
Thanks
