MascotRejct
So i uploaded all my photos from the job onto an imgr album. I probably should have taken more pictures, but I was covered in grime most of the time, and didn't want to get my phone all dirty. Replaced all the gaskets down there, crankshaft bolt and front seal, timing belt, water pump, timing belt tensioner and tensioner pulley, timing belt idler pulley, camshaft front and real seals, valve quide seals, valve cover gaskets, head gaskets (didn't need it, but I was down there and taking the heads off made it easier to to the guide seals anyways), exhaust gaskets, gaskets from exhaust manifold to down pipes, both upper O2 sensors, plugs and wires, thermostat, and temperature sender. When taking the heads off, I left the coolant cross pipe that goes form head to head attached to the drivers side head. I couldn't easily get to the bolts on the driver's side and said screw it. Also, I made one of the tools to hold the crankshaft and camshaft sprokets that was posted elsewhere on this board. Worked like a dream for 1/8th the cost of the mitsu one.
Here's the link:
http://imgur.com/a/02HRx
Thanks for all the help that people provided from the forum!
Edit: Also, i have a video of it running after the job. Not the best quality, but figured I'll add it here anyways. Why not right?
https://www.youtube.com/watch?v=uv7aNVgeYgQ&feature=youtu.be
Here's the link:
