Just purchased a FWC "Finch" 70" 535lb camper for the back of my truck, so the camper overhangs the bed about 10" shifting more weight than I care for past the rear axle. So I've been researching new suspension and tires. Sounds like the OME Dakars HD rear spring pack is a very good solution but am not sure between the Radflo/PRG 2" coil over replacements or to go with OME std/Bilstein. Wondering what shocks I'd need in the back if I was going to upgrade the stock NISMO Bilsteins with 89k on them. Also where to purchase OME stuff?
Anyone have any experience with the CC hauling a 535lb camper, gear, etc. possibly totaling 850lbs? The camper might come off for winter so some adjustability upwards on the front may be welcome to balance out the rake on the truck. Trips without the camper in the winter would be short sorties up and back down local canyons.
Also, if I'm going to purchase new tires, would a size change from my current 265/75/16's be warranted?
Thanks
Thanks
