NH Moto Expo
So I did something that may seem foolish but I've done this with every car I've ever owned and never had a problem. Driving my 2006 Montero, I was coasting down a grade and slipped the truck into neutral. Then I switched the ignition from run to Acc. This usually does nothing,(except save fuel) but in this case there was a racket under the car and felt like it was still in gear. It was like letting out the clutch on a manual car. Like I say, I've done this in GM's, Dodges, Audi's and VW's all without incident.
Could the transmission be locked up? Keeping the flex plate attached to the engine? Is this normal for this car? Nothing seems to have come from it but I found it quite scary that if the engine died so did your ability to coast. This was in 2Hi not AWD setting.
