Gladiator Pop-Up Pass Through Camper Build
Mules
That looks amazing. I am a big fan of lighter woods, and clear finishes. I would go with a clear finish as others have mentioned. Lots of luck with the clear water based varnish from Rust Oleum... their diamond cote stuff. Dries quick, sands out nice and after 3 or 4 coats it is a perfect finish.
I used it for my desktop on my custom standing desk in my home office ( the interior one version ). Dried VERY hard and has stood up to 2 years of WFH with no issues.
Stoked on the modularity factor of this setup.
I was struggling whether to go light and simple, or go full on cabinets and kitchen. My 90/10 concept won out. I use the truck as my daily driver and to haul stuff 90% of the time, and 4 wheel/camping 10%. But I love the 10% so much!
Light, modular and simple! I think the furniture is only about 60 lbs. I hope to have the bench cushions by next weekend. Almost time to go camping!
1000arms
In this case, I want the bottom of the platform to slide easily against the carpeted truck bed bulkhead, so no bedliner on the bottom of the plywood. I might do a smooth finish, but add a few small velcro tabs to hold the cushions on place. Still deciding. I'm done for now, it's been a busy weekend.
:unsure: ... No epoxy inlay? ... :)
Mules
Are there any good DIY ideas on how to put bug screens in my roll down truck windows, while camping?
1000arms
Check out DIY Window Screens for Car Camping at EpoxyWorks.
WanderingBison
We absolutely love our roll down window screens, albeit they don’t make them for your rig. But it’s certainly doable (especially someone with your skill ) to make someone identical for your use.
Aside from providing the necessary ventilation, they are the perfect size to allow them to remain in place in rain when paired with window visors.
I think the link will give you plenty to work with but let me know if you need some additional close ups.
Mules
These look great also!
Mules
I was pretty excited when I saw what showed up from Fed Ex today. It only took 5 minutes to open the boxes and throw the cushions in the camper. I'll take some better photos when I open up the camper this weekend.
Mules
IMG_7215.JPGIMG_7218.JPG Well I liked the idea of painting but I wanted a tough surface, so I choose water based polyurethane, colored black. This is the same stuff I've used for 30 years to clear coat wood floors in houses, just with a satin black color added. I put on a couple coats, while sanding between coats. It should be very durable.
I definitely like that I can put in and take out this furniture in 5 minutes.
Mules
Since I'm a better carpenter than seamstress, I designed the layout around stock cushions. This might be a good concept for a 4 door Wrangler also, just with lower seat height and shorter cushions.
Petersmithinak
