Glow Plug Question...
4Rescue
A very lucky friend of mine has gotten himself a RHD BJ40 with we belive a 2b diesel motor in it.
Anyone know the part number and Voltage for the Glow plugs in this motor?
Cheers
Dave
Good for him, the 2B was a nice little engine, an upgrade from the original B engine but not quite what a 3B is. The place that would have what you need (information) is here:
http://forum.ih8mud.com/diesel-tech-24-volts-systems/
I had a very quick search and could not find it but if you post up on there the guys will tell you both the factory and aftermarket part numbers.
Thanks guy's I was just about to head over there... now what the heck was my password again... HAHAHAHAHAHA.
To be honest, I haven't really poured over this thing to really find out what's actualy under the hood. From what I read, it's more likely that it's a 3b??? It's an Aussie Truck, and it's in pretty damn nice shape. He just had it re-painted the original desert tan color and just finished re doing all the weatherstriping. It's bone stock and really strait. I gotta say I'm a bit jealous.
Cheers
Dave
If it is a 3B then here are some specs shamelessly pilfered off MUD's diesel section:
Manual 12V
1980/10 – 1981/10 BJ60
Toyota=19850-68010 12V-10.5V
Nippon Denso=06710-1330
NGK 7493 (Y-147T old number)
Bosch 0250 202 058
Manual 24V
1980/08 – 1981/10 BJ42
1978/03 – 1980/06 BJ40
Toyota=19850-68040 24V-20.3V
Nippon Denso=067100-1161
NGK 3030 (Y-178T old number)
Bosch ???
Superglow 12V
1981/10 – 1985/10 BJ60
1984/11 – 1986/08 BJ70
Toyota=19850-68050 (51) 12V-6V
Nippon Denso=067100-1680
NGK ???
Bosch ???
Superglow 24V
1986/08 --> BJ70
1985/10 --> HJ60
1981/10 – 1984/10 BJ42
Toyota=19850-68060 24V-14V
Nippon Denso=067100-1460
NGK 2188 (Y-197R old number)
Bosch 0250 202 076
for the 3B 40 series refer to the manual glow either 12V or 24V depending on the truck.
Once you have the Bosch part number, you should be able to find it fairly easily in most American parts stores as well. It will be 24 volt and probably cross references with several other part numbers. For example the best source for Mercedes glow plugs is Autozone at $12 each for genuine glow plugs (versus $60 each at other locations). If you google "glow plug test", you can conduct a test with the glow plug out to make sure it is working. No sense in spending unneeded money on new glow plugs if they are not required...
Also many glow plug failures come from poor connections. Toyota uses that voltage resistence strip to get the plugs to glo longer at a lower temp. I got rid of this and uses high gauge wire, it glowed much shorter and always reliably started even at 10-20 below with the truck under 5 feet of snow sitting for days on end (I was in Alta Utah at the time).
I'm looking for a photo of the wire but can't find it... I used I think 12 gauge and standard 10 gauge crimped connectors to the glow plugs themselves. Similar to the Mercedes setup but with larger gauge wire. If you experience trouble starting, glow 2 or 3 times. Do not use ether, use something milder like WD-40 to start it during emergencies... Ether can blow your head gasket or worse...
Cheers, Andre
empireoverlandza
