Goal Zero Nomad 13.5 Vehicle Battery Charging Setup
expdtnoffroad
I was just about to pick up the Extreme 350. How much longer before a 60 watt panel?
Lawmaker for now you would have to combine a couple of Boulder 30 of Escape 30 panels. I don't have a lead time on bigger panels from Goal Zero yet. It could be 3 months it could be a year.
-Jim
Lawmaker
-Jim
Ok from what I am reading they are the same price. Same 30w. Both Rigid but the Escape folds into a briefcase. Boulder says that it can be linked to other panels. Can the Escape?
I like the Escape because of the folding more secure features. The boulder would be better mounted. The Escape comes with folding legs. Do you have any preference/experience that you would like to share?
Would an extreme 350, Ext UI and 2x escape panels work?
expdtnoffroad
Lawmaker you are on the right track. You can pair up to 4 of the Escape briefcase panels with a combiner cable. Both the Escape and Boulder panels are great and both will work with the Extreme 350. If you are going for one or two panels I would go for the Escape (my preference). If you need more power I would spring for the Goal Zero tripod that's coming out for $200 and then get a Pelican case to store the 4 Boulder panels. You can mount 2 Boulder panels on the tripod. However I would recommend saving the $200 on the tripod and go with the Escape panels if you are only going for 2 panels. This is a much more utilitarian approach.
-Jim
expdtnoffroad
Yes I am leaning towards the Escape also so that I can man pack them to another AOR.
Is the cable this: http://www.goalzero.com/shop/p/36/Solar-4-7mm-Splitter-Cable/5:1/
To hook two panel together to the 350?
I am surpised the kits with more than one panel do not have a connector cable listed as coming with the kit.
Lawmaker that cable is for daisy chaining 2 Extreme Power Packs together.
The cable that you would want for the Escape panel is this one: http://www.goalzero.com/shop/p/36/Solar-4-7mm-Splitter-Cable/5:1/
Salue
It looks like both your link and Lawmaker's go to the daisy chain for the Escape/Elite panels. If you do use the Escape panels to charge an Extreme (350) powerpack, you will also need this adapter:
http://www.goalzero.com/shop/p/27/Solar-4-7mm-to-Input-8-0-Adapter/5:1/
Salue
Salue
Jim,
Did you already do a writeup of the Goal Zero products you tested a couple weekends ago or is that still in the works? If you already did, can you point me to the review? If not, looking forward to it.
Cheers,
Salue
wellsasw
