SinCityFJC
Monthly Run for www.SNLC.org & decided to run Gold Butte while we still can (check out Gold Butte under land use)
A bit over an hour to turn off from Vegas, we went in through Mesquite and topped off before a long day on the trails.
A good example why you shouldn't wheel alone - the 80 just had new rotoors installed & shop was sloppy with proper torque on caliper bolts
Checked out this big a** hole in the ground called Devil's Throat.
On the Way to Gold Butte
Not much left of Gold Butte
