Warning: shameless plug
Title of this thread caught my eye, since I had built my rig as my personal version of a Unimog alternative Expo rig.
http://www.expeditionportal.com/for...-Dodge-Ram-5500-4x4-w-Arctic-Fox-992-S-Camper
Started with a stock Dodge 5500 4x4 for several reasons, some of which being:
-6.7L Cummins diesel- add Black Maxx Tuner, EGR & DPF Deletes and it has more power than a Mog can dream of
- factory exhaust brake
- 19,500 lbs GVW
- Magna 7500 lb Front axle, Dana S 110 Rear 13,500 lb axle w/ very large disk brakes
-add 365/80R20 MPT 81's on double beadlock reversible rims- turns approx 2000 rpm's @ 120 km/hr in 6th gear (would need transfer case doubler for even lower crawl gearing- mog goes much lower)
-Transmission PTO
- Crew Cab with all the creature comforts
- lower cg (lower axle clearance without the portals too though)
- Price: got a near new truck, with warranty for less than the price of a much older Mog
-parts availability in North America
Add on a high end slide in camper and I have all the comforts & maneuverability, as well as the option to off load it for a work vehicle as well, hauling trailers, etc.
Not knocking the UniMog at all, would love to have one (looking for U1300 steer axles or similar to put under my Dodge 2500!), this was just some of why I went the route I did when deciding on a vehicle to start with.
Depends a lot on where you live and/or travel, here (NA) the VW LT is rarer than hens teeth- Unimogs are plentiful in comparison I'd say! Dodge Rams are everywhere to say the least
