Desert Dog ESQ
Like new (never actually used other than a test) Grizzly 60 rotomolded cooler. I purchased, loaded it up once, and realized it was too large to fit in the location I needed it to fit inside my camping set up. The cooler comes with the add on accessory ice divider and tray. This is literally as good as new. Unlike the Yeti, this cooler is made in the USA (Iowa). It is bear-proof while locked and stay cold for an extended period of time compared to a regular cooler. I prefer local transaction (Santa Fe/Albuquerque region), but I will ship on your dime from 87507. $225 .If interested, email me at bvandenzen@gmail.com.
The following information comes from the Grizzly website: "The Grizzly 60 Cooler is the perfect outdoor cooler to accompany you and your crew on a week’s worth of epic adventures. Leave no snack behind when you’re working with 60 quarts of space for food, drinks, and ice. The G60 is a 60 qt cooler equipped with a silicone rubber gasket to keep cold air trapped, extending the longevity of your ice. Its pressure-injected insulation is stronger and more durable than foam, while also being lighter. And, its Rototough™ construction makes it rot-proof, dent-proof, and leak-proof. Meanwhile, tie-down slots help secure your cooler in your truck, boat, or UTV. At the end of your journey, the 2” drain plug allows quick and complete draining of your cooler. The Grizzly 60 Cooler holds up to 72 cans with 20 pounds of ice. Made in the USA." https://www.grizzlycoolers.com/shop/hard-sided-coolers/grizzly-60/
