Hannibal USA
Hannibal Impi Tent
Hannibal tent in lockable, streamlined hardshell casing.
Want the all the qualities of our regular hannibal rooftop tents in a package that doesn't require a safari rack? The Impi Tent is just for you. The clamshell design of this tent makes it possible to mount on nearly any vehicle all the way from a Chevrolet Suburban down to the diminutive Mini Cooper. The low profile fiberglass design of the Impi keeps wind noise to a minimum, which makes for quiet driving and the most fuel efficient tent design on the market. The fiberglass shell also protects the tent from UV degradation, thereby extending the life of your tent, while keeping maintenance to a minimum.
The Impi has been designed with your ultimate comfort in mind. It has three access doors, each with mosquito netting for maximum ventilation. The standard Hannibal quality mattress, with 3” high density foam, and a washable cotton cover, guarantees your comfort in even the most rugged of conditions.
Hannibal Impi Specs:
Height Width Length Weight
Opened Tent 59″ 51.2″ 86″ 154 lbs
Packed Tent 12.6″ 51.2″ 86″ 154 lbs
Features:
The Impi comes standard with a factory fitted National Luna Light. The light is easily connected to your vehicle via waterproof plug on the case.
Two gas shocks enable the tent to open itself.
The ceiling of the Impi is covered by a quilted thermal lining to provide insulation from the heat and cold, and to prevent condensation.
$2,000.00 USD
I have a handful of guys that want these in the USA again if you want one contact us So we can get a large shipment coming this way
Features:
$2,000.00 USD
