Headlight upgrade 2000 fg637
Installed the Narva + 100s but no opportunity to compare just yet. Filament does appear to be more tightly wound than original bulbs but nothing else remarkable.Debating about putting headlight protectors back on, bit old but cleaned up ok and I repaired cracks which weren't in the beam area. Will update at some point.
Came across JW Speaker references in my research. Bottom line is LEDs aren't approved as retro fitments over here. I would still consider LEDs as it would only be for occasional use in remotish areas and if I could convince myself they weren't hazardous to other road users. We'll see how the halogens go. Narva do make LEDs in the H4 with heat sinks etc and claim a well controlled and directed light pattern.
Update - Narva bulbs have improved things somewhat, but not nearly as dramatically as they claim it would. Doesn't really surprise me. Still a dramatic difference between high and low beam that leaves you groping in the dark. The search continues.
WonaWarrior
