FastGlass
I posted this elsewhere too, but I need all the experience I can get on this stat, so:
....I'm in the process of ordering a Prorock 60 semi float rear and PR 44 unlimited front and the good folks at Northridge are talking of welding on some Synergy HD track bar brackets front and rear before sending them out to me. I have an AEV 4.5' RS to install...springs, high steer, Bilstein 5160 res shocks, but I'll be going Clayton for the long arms in the rear.
Anyhow....Can anyone help me figure something out here?
The AEV 4.5 RS provides a drag flip kit/high steer setup….right? This is to alter and raise the roll point? It also centers…or trys to..the axle assembly?
A bit confused here...
1)This synergy weld on bracket will work in conjunction with…or INSTEAD of the AEV system?
2)What does the Synergy one do that the AEV one doesn’t?
3)Would it be wise to add a beefed up tie rod (Syn HD), F+R track bar (are these included with AEV…if so, are they sufficient?), HD Sways, drag link etc while were mucking about down there?
4) “IF" I go Clayton LA's in the back…upper and lower…will the welded on Synergy bracket be in the way or work with this?
I don’t want to do this twice…
Im trying to get this in this weekend for their black friday deals...
Thank you all!
Thank you all!
