I just bought my first van it's an old style (90's?) conversion van (87 GMC Vandura). The previous owner did not use the 2nd battery so he couldn't tell me how to use it. I was wondering if someone here can give me a run down on its operation. Here are some pics and my thoughts.
This is the starter battery, the blue cable (bottom left) you see runs back to the second battery. I assume this means it can be changed form the alternator.
I followed the blue wire to this switch. It appears the I should switch this to 'ON' if I want to charge the 2nd battery. I'm not sure what the 4 options are that are written there - the switch is just on/off. The switch says Cole-Hersee Co. Boston - Battery
Following the wires further it goes under the van and up through the floor to this space. Its a cabinet that has a plastic enclosure for a second battery and a plastic hose that vents to the outside of the van.
Some wires leave this cabinet then branch off to a Circuit Reset (I assume this is a breaker, I didn't see a fuse) and another branch out to an alarm (I'm not exactly sure what these are or what they are for)
Wire Branch-top right goes to breaker
The Breaker Reset
This branch goes to the "alarm"
Alarm (I have no idea what this is)
So those are my assumptions. Can anyone fill me in on this system and how it operates?
Thank you,
Al
The Breaker Reset
Thank you,
Al
