I can't find a good picture on the interweb, but what a lot of guys do is weld a piece of square tube to the plate the spare mounts to centered on the wheel center hole. The tube has a flat plate welded to the other end (small enough to fit through the wheel center hole) with either a couple of holes or a couple of studs welded to it. Very simple and probably not to expensive if you had a shop do it.AZ_Husker said:Looking at pictures, occasionally I find people with their hi-lift mounted on their rear-door-mounted spare tire. I have not been able to find one of these mounts. Does someone know who makes them, or are they custom made?
Thanks
