I have read numerous online threads of people complaining about relays wired into the high-beam wires in the 2012+ JK Wranglers. From what I understand, the PWM pulses the electrical current to things in the vehicle instead of allowing direct/full current to flow. Does the chatter come from PWM flowing through the #86 and #85 terminals on a standard relay causing the electromagnet in the relay to "chatter"?
I am planning on wiring (3) micro relays actuated by the high-beam wire in my Jeep. These micro relays will act as a gate between the (3) auxiliary light relays and the (3) in-cab switches. This way, when switching on the lights in the cab, the switch signal will be stopped at the micro relays which won't close until the high beam is on.
Has anyone successfully ran relays off the high beam wire?
