Metal Twister
Highly Motivated
Ive never built one of these but thought it looked kinda of fun. I still have to weld a doubler plate to the top and bottom of the square receiver hitch material. and thinking about doubling up the 1" grade 8 bolt where it is welded to 1" .250 wall molly for the pivot. I need your opinions on if you think its stout enough or if it needs more beef! Thanks in advance...
The tube rotates on the poly bushings and a moly sleeve insert. The through bolt is 1" grade 8. Zert fittings still need to be added.
