Homemade Roofracks.
Parras
Keeping this post alive with ideas.
Working on this for my JK 2dr, fab parts in process. I did not like what is on the market plus I cant pay for it.
Function > Form
Looks like a good design. Are you doing mesh on the bottom? I initially wanted to but decided against it partly due to cost, partly due to 'difficulty' to install (ie. stretching to prevent sagging)...and the 75 million little welds.
What program did you design that with?
Hawk136439
I built a drop in basket for my Xterra to try and utilize the space between the factory rails while keeping loads as low as possible. It also replaced the factory cross bars with unistrut to allow easier customization.
FQZcb6CTitYwUZRBnxNk_6DdQfL8vHFUbtD4OuFYWAVOnLvb9JtvuCcDBBH0srn8-GsI_MRFttXp5qtGU-eqAOWT6l_2Az7luHTdPiR3SiMeOp32T0Y9wo1qmzMw4eCRC98gcmeqVFPLdUeezgYmHg5P2ngfm8cUUoWyYZotCLn11C4kP_ubVAztMo11My0IZEuj0FHjlzaLVvLn3PqFD3rDeOT91ltdH5JeFo7yXht17xkkYYsZ6bxf0AnhVdp19wJdL6OCEqI7AnHB97Fk8a1GXQHe9ls3cjR3mSquFN-fC4yylO2cHt-BFZ1HM1ixTsj4OekgyCrRJyoCOe126KPmjVMcKk4BjKXCZ_CZrbtecTsHGRQXcxCf4cAQxqRwBqjNuCRETK3mIoEdi-9lbuku808FjSCTDCMFf7NPyQFrwIu0COANbkP4jtVCSH8r1Qbo6QX8-OE0A3yROaMzqcbr9qaLsI-FeBsR8L6yxPN-2vaci1sCMfSFoZejoTwEdsDJcwz69zvnvJezHtdHEBb6iE34KXgQLNFgtoTGllWorKFTdTqqwyLmY0T1tFmCGONWc08NLObNWI2XRaUQIjHBRPSzCXYkv36zwmiQO0SIrxCy_6jIwctdM8Eo4e6jwmQZ40nCMk5mrtOUcBzkxMSHkOzCenmFQs8=w944-h531-no
wiIkBroZVeq29Zr82RtSFYHs2-ziSy4hvv0_RinbKk8iaZUlSWWQKda-R7mEGugdgNXKeWhCfL8F4YKaNQ_HRyk7J6WU_JB3iiyfUWfJ74G8i9Re_-kszM7pY-uTEc6BTKYvyw5cpG37-SfQ1hk0-8QMD6wHIWq3oeYkkZnOzfb5GiQiPg4jCGlX1VeC39o8dYEe5_NzbYKZIJAxlJfepbhdySxrcUNNQSMZCtZnbGos7JWLrISUzjt4PdyDysmD4D88GXKO_JlARWolW2Vzs_YeMSFa7gifrl25kz_6lhHX9klYpXLqt6x1fDvJ_uL69AV0jIaUpSLo2CQAZWglfMqFWY-RXErC_qpm4uk0dsLkMmNcyOUw67dv5H3eRLrrDE0SOv7BQ5aTVWTUt0_spEiLvn4wJUjHwkvtSpb7xnqUj-N1GzqT9X389t42hNPbUhkEpaOnBiZljvDyv93r003pgeUIBEAJutAwHEFfGkYWFDEyZFK3aRqHSVVIg6SvfAMW1zl6Hlc58UnCarQtIoOSj9ZbQTZ6sjrPCK4sy18ZGOR-qGE6vfHeeQXtgdCjiA-Vj_iLTt8hzfbdgFI3ARQmMyBpXGZ1ZqqYkp3I2K0m9NZl3a1tBxAOkcoBF9yFL_XiVNMQ9Yg68pvOt9dxYiJCG5zZ-VJI9HQ=w944-h531-no
the unistrut is allowed for wider mounting options so we were able to fit both kayaks on one xterra
Zu_abmdIz6q7vDR17j4PJsPzg18xCFgRibSJKE79AB6KDDpPzPzE_IXRIhqxlno1ouqFXkDimLWUmVqL9nvrtVnz9sUBrfMSJBflyBN4DKH2Iz4Sm-sJnwjTqbSw2rB01WXCIhhxRc9EtqAMAXhQP_NP4Y3vDHBM9XPMHI-2ASHVXsZslwktsrM_jbLbeS4Z32YoanIUGoHMnbXwcWbF_bFnCzL1xYRtpibB5ujbzSRq6t_YFN1zkEx8y4uwXPZXVeLsBsC-c8L50ot6ycOM6LBZPhZB-TFlmBbGRdh9VdbY-nlhYnSisMhUYp5TH0mbJB0tKlVhlW_aEltwJwUNIOYPFaxXvRchUntArzgA1w79UdXR7RSRq1GiyEaRvDdIC4lpaiJahTJxa_Ow72OnqAEbQuYw1AwknEbQ3CaWsVVXj0Wup35v0fy-wt21wZRU0HbIG_cVOzsJ_HWD_XHam5z9pMXuyqUNuIzLo67fISmccye02pS9cG4Sf4imkUsZsnTHxwXIvmF7CwwfrOeXnPg3JDrVaBI9-eTxQa_YHy0J9ScHbVFCVA6elu6Vhximjf1g1ZH7zZhpaTF0WbnY-Apk7Ju0P4U3re8f6Ry9RmyogEicIkEztH2FZiuhnXiakOH4nyDdQiWuGB_Y6AfLmeEuponSa2wgIno=w944-h531-no
and the main purpose for building it was to mount a spacecase AND carry the generator on the roof at the same time.
XbBBrKJ9DWjEWE4LkLRm0n21dIGA9gBQr1cJH49MXXtRSGHDHycPnpU0bgumguD49yw2KSK8FJ6vhMWXxDR7k0y0d_KM_HhdIzObqKB0Dbq32mE2Kdt_tf3I23vm3xSvGEbQMXdzIVIV5Wo3BYkStXHQNBZl9fuotrvV2LsTalDiODK-gxgBjcGdmOHSzlW5Q1Q5B86g6ZveoPgwV4Xhg0AHYGnH63bRC12vpP0SxmvHT-YlzjMEMEV2oKR6VSDfquDnU6C4CDhxvnrO4EbmF3IPmJEDcbn6_ox7T0Q0Bxly06tcVNgTH9ymI5LoThWZwH5SYZEG7BzbgXCgq-hzdYUqsNWhSaY_Y2u7alL48P8UMGMYTNSafu38mw__DgVj2d9V3eJZbopMs9FH_FVlEI30OPbqUX5FzYW2eTPd50qRSpt4-RfDqmcqRW3GzIiB_RcZIvExXIHWwrjo63Vy_zozb-P4tTGPoKpm3eNxeY3JYb_Z1lyP5QsnWQ6FarzSp-LNgYlz2huWpc_qSj850qAAKeV5d9OEjnczCbslkSNhfwvcTE7TZ2qY8U0vTRF6g3UHwXSDDENMY4OMiSDqMrghOdgqHansaFjIr5K7uX09m_NxFbxYyfr_062fb8FcluC6ZKBqXK2mmmivHMHV3l0XIj8shi4rdm4=w944-h531-no
Parras
I am using Autodesk Inventor, and yes I am welding steel mesh at the bottom, you can make the mesh sandwich with a flat bar and avoid the point to point weld, but probably will keep some moisture. I have the time to make things slow and well done.
Gotowork
custom rack for Jeep Commander
Just finished mine. Still have a metal grid plate to install for the floor.overhead3.jpg
Sixinarow
Awesome racks, guys. I'm also wanting to build one for my JKU. It has a light bar with a-pillar brackets so I'll just use those as a base for my uprights. I'll post pics when it takes shape.
shmabs
2nd gen tacoma rack
One of my favorite threads here on expo!
Here's a quick simple rack my friend and I built for his regular cab second gen taco. It mounts to rails that are installed on his snugtop, its about 4'x7', he will be painting it and installing a fairing to finish it off.
robert
There's one on tacomaworld too I believe. :ylsmoke: Nice job.
Did you cut out some of the cross bars? Are you planning to reinstall them?
shmabs
I posted that rack on Tacomaworld too. I'm not sure what you are asking about crossbars, we didn't cut out anything.
Mike
shmabs
I generally make a simple fairing out of aluminum that contours to the roof with some sort of a rubber barrier between at and the roof. I've attached them to the rack with adel clamps, or sometimes welded brackets on the roof rack. I'll have to ask the owner what he is going to do.
WonaWarrior
