Hound-FJ62 LS3/4L65E Connect and Cruise
NCFJ
ever wonder why your E-brake seems to stick?
Packed in
NCFJ
Fresh out of the shaker. All gets coated with light oil, bagged and tagged. When used all hardware sees anti seize, lock tight, heads and nuts painted
NCFJ
Pretty close, above the seam on the firewall is already the upper body color. Inner fenders, engine compartment side, will be the same color. End result, same two tone under the hood as on the body.
To paint or not to paint? I go back and forth on that. If the factory plating is still intact, I leave them unpainted. The shaker does a great job of cleaning them up, but if left in too long, it can polish the plating away.
Nice work Stan.
NCFJ
Matt, the original plating is generally near rubbed off on much of the hardware already. So I make sure everything is coated with either anti seize or loctite and the exposed heads and washers and nuts are painted.
I hoard hardware like a squirrel. One of the benefits of taking in donor vehicles (when doing motor swaps, etc) is that I get to strip the vehicle for all its hdw. Most times the hdw is in nice shape and finds its way onto a customer's project, plating intact. And it's OEM to boot.
NCFJ
You want to know what commitment is? Pull the tail cone off a brand new crate 4L65E and cut a couple inches off the output shaft!
NCFJ
Spud shaft, adapter, silicone under spacer to help prevent cross flow of trans fluid and T-case gear oil.
WonaWarrior
