house battery with no connection to alternator
hitek79
I purchased the Renogy 100W panels. I have room for at least 6. More if I want to start taking up some of my roof rack space.
So today I came across something potentially interesting. My rig is a 24 passenger bus. It has a good amount of wiring and lighting in the back, and today I was under the bus and I came across a second battery. I'm assuming that means that I have a high output Alt that capable of charging that battery as well.
hitek79
So I've decided I'm sticking with the simple set up for now and not connecting to the alternator. Can anyone help with wiring diagram so I don't mess anything up? Here is my parts list as of now.
6x100w Renogy panels
Morningstar MPPT 60A controller
645ah battery bank
Noco Genius for shore power charging
Morningstar SureSine 300w inverter
Blue Sea fuse block
Lights/chargers/etc.
There are a million diagrams floating around, and a lot of them seem to be slightly different for various components, so I'm just trying to understand why certain things go in certain orders. Thanks for any help!
Kevin.Hutch
Excellent advice, the best system is a separate charge control system for each battery, however if your battery replacement cost does not exceed the regulator/charge control system cost, then take my advice and please yourself do not over engineer it, unless the learning curve it the object, thousands can not be wrong.
We survive with 180watt MPPT solar, 100a/h battery for 7 sunny days with a VSR and a 150a alternator for boost charging when we travel. We chose not to travel in rainy weather.
The principle of batteries and their charging is very old but the technological changes make it a mature but still evolving science, full of many contradictions.
Size, weight, battery type, solar surface area, how long camped, not to mention usage, play significantly in establishing the best compromise for each solution and the more you learn the more you realise how little you know.
The chances are you will only ever replace your battery once before you replace your vehicle so consider the cost.
Kevin H
iStan814
