How do I sew a sidewall.
jgaz
How about the urethane adhesive that is used to set windshields? I have no experience with it other than it's intended use except for using it to repair a barn door weather strip in the middle of a Michigan winter.
If you came across a mobile replacement van, the tech might give you an almost empty tube to try. I never set nearly as many windshields in a day as most of these guys do but usually used a new tube for each job since the urethane starts to cure quickly which made it harder to apply properly.
jgaz
You can just visit Auto Parts Store & buy the stuff nowdays. They changed its formula so it wont work for cooking ‘meth. Its no longer DEA regulated product.
Btw, it works great gluing patches on fueltanks also...
Seriously!? Cooking meth! My wife tells me I “gotta get out more”, maybe she's right.
Plastic or metal fuel tank patches?
The things you learn reading random threads!
Stumpalump
The tires held but the shoo goo cracked real easy. The threads are pullin thru the rubber but the shoo goo is weak. I'm gonna grind off the shoo goo and put a patch on the outside of the tire for one more go at it. The tire was spun constantly, jumped and slid sidways. Three cars ripped their front suspensions off and I had to drive over one car that wrecked to get out of the way so I gotta say the fix worked well.
Big heavy V8 cars piled up.
Field repair
LS3 powered
Honda 3.5 V6 in a light mid engine car.
3 more Chevy LS V8 cars.
Mine is super light and runs a tweeked factory supercharged Chevy ecotec 2.0. 13psi boost 275 hp. Driving the dunes is a blast but we have just as much fun at camp.
BritKLR
Kapitis Indagatoris
Beavis and Butthead method
Bathtub method
Cold method
Big gulp cup method
Mom and pop method
......Hundreds and hundreds of methods thanks to the internet.
WonaWarrior
