How do you pros add aluminum skin to a steel frame?
opp
When you have your frame done. Easer to cut foam with no skins. Press foam against frame mark/ cut . Then mark up and inside. That way if out square no big deal You will cut one time. If your like me so sorry. Cut it ten times to short and out of square
Essayons
3M makes the panel adhesive that Turtleback uses for aluminum to steel frame adhesion. Same stuff they use in the auto industry..It's applied through a caulk-gun sort of arrangement that mixes the A-B (like epoxy) parts. I might use it on my trailer project if I go with aluminum.
Essayons
16 gauge steel is 2.5lbs per square foot and aluminum is .89lbs in the same comparable thickness. Yikes
With aluminum you won't get the same strength as the steel with the same thickness. Aluminum will have to be thicker as to not buckle/warp, but the cost goes way up per square foot for the aluminum...a trade off, lighter than steel but expensive.
weekender
I really like the idea of glueing the sheets in place. Very tempting. We use some really nasty stuff at my work to glue the windshields and side windows in on cars.
