Howski's Defender 90 Build Thread
Howski
I've got some great news to report which I'm sure some of you have heard - the 90 is coming home! Will Hendrick, a fellow Rover enthusiast and attorney for the two dozen of us involved (might I add pro bono) cannot be thanked enough for the countless hours he put in for all of us to have our Rovers coming back. I should be in receipt of it over the next few weeks and out on the trail shortly after that.
Cheers,
Kevin
Howski
I'm glad to report the 90 is back and running well after having to replace some sour diesel fuel. Can't wait to get on the trail shortly and hopefully plan a longer trip once the weather cools
rlynch356
Defyota
This is pretty common - mine still leaks around the clutch peddle - you can do a good bit of sealing. Land rover actually has a water proofing manual for the defender.
on the clutch peddle - look at the slave cylinder on the LT95 after you re-bleed the system and verify you do not have a Master cylinder leak (which manifests as break fluid on the clutch peddle)
Clemtiger84
