I have been looking into getting a dual battery setup for my '02 Xterra and I was thinking of getting a Kodiak Industries Dual Battery Kit like this one:
Then I started wondering why I needed two batteries instead of just one bigger one. That setup comes with two Odyssey PC1200 batteries. The total dimensions of the two batteries measure 200mm wide and 340mm long. Instead of two PC1200s should I get a single PC2150 that measures 170mm by 330mm? The PC2150 is a Marine Dual purpose battery while the PC1200s are regular automotive batteries.
Here are the specs of the batteries:
PC1200
Keep in mind there would be two of these:
530 CCA
44 amp hours
78 minute reserve capacity
$200 each (also need to buy an isolator)
PC2150
1150 CCA
100 amp hours
205 minute reserve capacity
$390 (Only like $300 if I get a DieHard Platinum which is the same battery)(Don't need to buy an isolator)
I know that with two batteries I can use one to jumpstart the other, but I don't see any other advantages, especially given the specs above. Seems to me like a single big battery is cheaper and gives better performance.
I will be using the batteries to power a fridge freezer as well as campground lights as well as an inverter for as long as possible without running the engine. I also plan on upgrading my stock 80ish amp alternator to one with 175-200 amps.
So what setup would be better for me? The two PC1200s or a single PC2150? I don't plan on discharging the batteries very often, just maybe once a month while camping.
One the car is off and the batteries isolated, there isn't very much power to play with on the AUX battery.
PC1200
530 CCA
44 amp hours
PC2150
1150 CCA
100 amp hours
