I need shocks - I am clueless
calamaridog
So I had to go with a different size bolt (both in circumfrance and thread size). As a result the shock bolt housing does not fit snugg and the shock has movement when I drive and makes a loud sound. I am told that is a bad thing!!!! In the pics you can see the "gold" colored non-standard bolt I was forced to use. Again, the welded on nut has stripped threads, that is the problem.
My first step is to find an M12 bolt long enough to use, that way it fits snug on the shock bolt housing so as to not allow any play. Maybe find someone that can custom make one?
Couple options. The most expensive option would be to take it to a shop that can weld on some new shock tabs.
The second option is to find a sleeve that will fit over the existing bolt to increase the diameter to your needs.
Last, you can just find the right diameter and length bolt.
You are on the right track.
xander69
