Tear Down
My kayaking/camping trip got cut short this weekend as my girlfriend came down with some sort of bug so we headed home early. This gave me most of the afternoon Sat. and all day Sun. to work on the teardown. I've seen people strip these things down for sandblasting to varying degrees, but I decided that a complete teardown was the best way to go. Most everything came off without too much trouble except for few notable exceptions. PB Blaster, a propane torch, and a small rotary cutoff tool were required to get the job done.
All said and done, it took me about 20 hours to get it completly apart. It was hot and near 100% humidity this weekend, so I took it slow and easy with lots of cold beer breaks to ponder the possibilities...
The 4 reflectors were a pain. Most of the flathead bolts had to be cut off.
The underside of the tub was in surprisingly good shape.
Not surprisingly, the worst rot I found was around the drain plugs. It took everything in my arsenal to get these things off. Note the broken screw extractor.. those things aren't cheap
I'm not certain if these springs are reusable or not. How can I tell if they need to be replaced? They look OK to me... I'm hoping I can just replace the bushings, but I'm no expert. This is the only picture I have of them currently. I will take some more tonight, but they are already off the chassis.
I have more pics from Sunday, but I suspect most folks are interested in the build-up not so much the tear-down J
