S
alright so what's the skinny on the bluetooth cb? I know what it's supposed to do... does it actually do it, and does it perform well? Easy to use, and worth the money?
Hey, you know more than me. This is the first I have heard of Bluetooth CB. What does it do?
While you were right to consider backing plates on the first aid kit and fire bottle don't overlook the weak link there. That whole flimsy panel is hung on little plastic clips that are not known for their durability. Before hitting any bumps or slamming the door you might look at fastening through the 1st aid box and into the steel of the door with some kind of blind fastener.
Kind regards, Josh
Something to consider for the first aid kit - if you are on any sort of incline forward or to the driver's side it is likely that the contents of the kit may spill out when the box is opened. Having the box removable would prevent this and make you mobile for first aid care.
I like the compressor mount.
Brian
so, it basically connects the person on the other end of the phone to your cb, as if they were on a radio elsewhere? You push the button on the mic and it transmits to them, you let go of the button, and it's like putting your cell on mute?
Almost. It does connect the person on the other line and plays them over the CB speaker, or external speaker just like if they were on a CB in the car next to you. However you don't have to key the microphone to speak to them.
Sounds like it turns the CB into a handsfree device for your cell phone? Or does it make it so the person at the other end of the phone link can communicate with someone at the other end of the CB link?
got it. wow, thanks for the info. I might have to check this thing out!
