International 4700 4X4 Rescue Conversion
motorman
the best part about the sliding bed & table besides no legs
is that i will be able to work in the early am while my better 98% remains in bed
no break down / setup to disturb or disrupt
just pull out the table and get - to - work . . .
extends over 35" past the bed
bear in mind that this is a 60' wide queen bed
will integrate a spring loaded gate pin into the underside of the table to provide the stop points for the slide & lock into place
ITTOG
Woh, woh, woh. Don't give yourself too much credit there. She is most likely 99%. I guess your building skills probably help you to maintain a 2% level though. ;)
Love the slide out table. How much play does it have?
motorman
funny you should say that
after 25 years of marriage i officially went from 1% to 2%
not that she has declined in any way
BUT i have actually improved that much
1% to 2% is a 100% increase my friend !!!!!
seriously out punted my coverage with my bride!
regarding the slides they are about 13" on center for the table mounting points and 18" on the cubical
the drawer slides are 40" closed 88" at full extension
closed there is almost 0 deflection / wiggle
fully extended there is less that 1" total deflection, 0.5" each direction
slide is rated 260 lbs and the butcher block weighs 50lbs or so
could a big rascal like me induce a huge radial load and increase this value, without question
but with the 60 combined points of attachment it is a rigid system
plan to use the 24" slides for our pantry
extends 32" (50"+ total) so we can police up items should they fall
motorman
productive weekend focused on the AC side of things
starting layout
i pulled the sink and kitchen base cabinet to organize the cables and add strain relief
ferrules for everyone
why Victron does not used studs makes no sense to me
'finished' the AC side of things
cables from opposite side of batteries to facilitate balanced charging / utilization
terminal fuse to protect the cable
400A fuse to protect the multi-plus
400A fuse in the lynxshut
50A main breaker
green means 'GO'
ITS ALIVE!!!!
motorman
the amazing part about ambulances is the fact that every circuit is a home run of wiring
i have not purchased any wire / cable except for the 6/3 wire for the inverter out to AC panel
. . . until now
had to purchased 6 AWG for the DC circut(s)
bringing power to the DC panel
power from the DC-DC Orion
ferrules or lugs + heat shrink for everyone
had to R & R the fuses as i had installed them on top of the leads and not fuse - lug - washer - lock washer - bolt order
buttoned up for the 10th time
only 90 more to go?!
great part about the electrical compartment location is the access to all the wiring connections
took the opportunity to install an outlet for the water heater
thought it best to be able to remove the water heater by unplugging as opposed to disconnecting the wiring
AC cables completed w/ strain relief
DC side in process
the 4 light zones are connected and working
the position where the switches are hanging will be the approx location of the Victron touch 70 screen
and below will be the location for switches
purchased blank plates from New Wire Marine
the one with holes was a test fit to see if the dimmers can be incorporated easily
dimmers on top of each respective switch
motorman
once more into the fray . . .
hauled the fixtures out of the box once more once
lifeproof flooring installed
cuts well with chopsaw as well on the table saw
utilized a gate spring latch to lock the table into the different deployment positions
clears the 'boxes'
motorman
wrapping up the wet side of things
this compartment is directly under the sink with its own 12 gallon grey tank
wired the hot water heater and plugged it in to the designated circuit outlet
utilizing braided stainless hot water heater lines for all of the water connections
minimizes number of fittings and the rubber gasket makes the seals 'certain'
i can always get a pair of channel lock pliers in there and tighten them up if necessary
have not plumbed to the truck coolant loop yet . . . this will follow later
utilizing common garden hose Y splitter allows me to shut off each water circuit separately
hot water heater problem . . . cut the supply
shower leaking . . . cut the supply
faucet leaking . . . cut the supply
shower is next and then the remaining water hoses will be connected to the respective hot/cold supply
motorman
water supply / fill finally addressed
it is internal and to facilitate external wall mounted filling would have forced other compromises in the layout / location of water supply
trade off for safety, simplicity & trouble shooting potential failures
this is all interior heated space
maybe 3-4mm clearance
installed touch 70 screen
switches w/ dimmers for the 4 separate interior light circuits
additional switch panel for exterior flood lights & chicken lights
and other circuits (fans, circ pump, heating pads
little bit of room remains for the heater & ac control panels
half the dangling wires are trussed up and we can finish insulation & back wall
and brought out one of the mattresses
very comfortable and supportive
not too far of a step from the seat to the bed
26 1/2" from bed surface to ceiling
24 1/2" from seat to bed surface
WonaWarrior
