International 4700 Ambo build
Baloo
"The Bear Necessities"
Time for a long overdue update, replaced rear wheel bearings and axle seals.
Baloo
3 gallons of gear takes for ever to pump in when it is cold out.
Deleted Member 183
I suspect that your truck has stud rather than hub pilot axles...
If that is the case then it is VERY IMPORTANT that you chamfer the holes on the inside of your M35A3 rims for your back axle and spare!!!!!!!
  • Like
Reactions: mog
