inverter question
BurbanAZ
I have found that in my experience the cheap inverters all draw a good bit of power even when they are switched off. Mine was
900ma when off that's not acceptable to me. I wired my cheap inverter with a relay connected to an ignition line so that my inverter can only be switched on when the key is in the ignition and switched on. Of course there is also a fuse at the battery.
I'll have to check to see what the inverter is drawing when off
