Progressive Dynamics Converter 4600 series 35 amp to replace the original inverter which was 20 amps, plus this one will allow us to still use our small 1000 watt Yamaha generator. Removing the old and replacing the new was a no brainer PLUS a new DC fuse board which I also installed as it has all the upgrades to tell what charging phase you are in. I should of done this at the get go but I'm a procrastinator now and then and this was one of those times. Excellent little unit.:wings:
http://www.bestconverter.com/PD4635-35-Amp-Converter-Upgrade-Section_p_350.html
