I may have an oppertunity to ride with a friend for 1000miles in 24 hours. I know very little about what makes an 'official' Iron Butt ride. I have heard that an official looks at your odometer, you keep signed gas receipts and another official reads the odometer at the end. It sounds interesting to me, kinda a 'badge of honor' thing. Don't know where we will go yet, don't know when, I just know that I think I want to go.
REX
Just a piece of advice regarding doing a 1000 mile day with someone else. Be sure y'all communicate BEFORE hand. It's a good idea for you both to plan the ride together. Having similar riding styles and similar gas ranges is also helpful. It's very helpful to plan, in advance, each stop and know which gas station you're planning to stop at. I've also found it helpful, when riding with others who've not done one, to have several "bail-out" points - 1/4 way, 1/2 way, 3/4 way. Know, in advance, any special needs each of you may have (some folks have small bladders, others need to eat every two hours, some need to stop and smoke, etc.). Be efficient at your stops because that's what eats away at your time - go ahead and start getting into a gas stop routine where you write down your mileage, write down your gas, and then check and stow your receipt. Doing a thousand mile day is actually more of a mental exercise than a physical one - do a ride that appeals to you and know your stops - if you're not enjoying the ride, stop - if you discover your riding partner annoys you, communicate, and/or separate, and/or stop.
As for documentation. Your start time is your first gas receipt when you fill up before leaving. Your end time is your last gas receipt when you fill up at the end. You'll need to ask someone to witness your departure and arrival (this can be a friend, neighbor, gas station attendant, etc. if you're only doing an SS1K).
I'm a long ride addict (as a personal goal this past year, did 2 a month) and a few things I've learned:
- use a tank bag with easy to manipulate snacks inside so you can snack as you ride
- use a camelback (I put mine in my tank bag) so you can hydrate as you ride
- when I'm feeling fatigued, that's a sure sign that I'm actually dehydrated and haven't been sipping from my camelback often enough
- gum is a good thing
- use ear plugs (cutting out wind noise dramatically reduces fatigue)
- get in the habit of moving about a bit as you ride and adjust your position BEFORE you start feeling achy (I tend to do a series of stretches throughout a long ride to avoid being too long in one position)
- if anything is a distraction or not right, pull over and fix it immediately, it's not worth riding a couple hundred miles with something that's an annoyance
- carry an MSR fuel bottle with fuel in it (if you encounter strong headwinds or get bad gas, you may find you'll need it)
- split day rides work surprisingly well (leave at 4pm then ride 'til midnight and stop for a rest then, get on the road at 7am and ride 'til 3pm)
- check in with folks at your stops so people know how you're doing and where you are (sending a quick text is fairly easy and takes less time than calling, plus, getting 'congrats' texts each time you stop is an added morale boost)
- if it's not fun, stop
