Is there an amazing tool to help replace valve lifters/lashers/tappets?
  • Thread starter Deleted member 144409
  • Start date
D
Guest
Hi all,
Is there a tool that can help change the lifters without taking the cam apart? I'm guessing something to mash down the valve spring? If so, it is vehicle specific or will there be a loaner at the O'AdvancedNapaZone? Or should I make one from spare PVC and hope?
Follow up dumb question but for piece of mind: Which direction does springy part of the lifter go? Against the spring or into the cam?
89 Raider, v6
Thanks!
David
Toasty
There is a really cool tool for the job, you have to remove the cams no matter what but you can do the job on the truck with the heads on. Maybe I can get a write up going over on the Adventure driven forum, I'm sure someone's doing them soon. The little end to the valve.
D
Guest
Thanks! I saw something, maybe that, similar but it wasn't clear that it would work. I assumed since it was for rollers, it wouldn't be useful. The video helps.
Thanks to both of you!
David
evomaki
Schely Products Inc. 91400B. I've done two Monty's using this. Worked well. Search this site for discussions on this topic.
Deleman
