rblackwell
We rarely draw our battery bank below 80% SOC.Great tips Rob,
I understand the thing about screws and agree 100% - avoid if possible. It has been a pain, but I have injected epoxy glue to each screw hole on my cabinets - and have limited the use of screws to the hinges ( s/steel piano hinge to spread the load), the drawer catches and to only two drawer runners. The cabinets are made from a Laminex/ply/foam composite - the doors are only 12mm thick and weight very little . On the two main "kitchen" drawers, I have the normal draw runners I which have screws with epoxy which the foam absorbs to make a solid block, then added another runner underneath to take the weight of the drawer.
I have a Webasto ST90 system very similar to your for heating and hot water - I first saw in Ron's GXV http://gxvmoghvn.webs.com/ when he visited us in Australia and was kind enough to take us through all the things in his truck in detail. We also decided that diesel power would be the way to go, similar Webasto X100 cooktop, also thanks to our time with Ron but we will make something to protect it. We don't have the same battery banks you do, only 400AH but may pack a little Honda genset for our round the world trip.
Safe travels and enjoy your trip.
An item that I have found very useful is a Sterling Power battery-2-battery charger for charging the house AGM batteries from the truck battery pack and alternator.
The Honda gen is a very good idea - for cold weather you can store it inside so to avoid cold start problems that we have with our Onan diesel. Do you have an electric block heater in your truck as well as the Webast ST90? You could also run that from the Honda.
I did not like the diesel cooktop initially but have come to like it - unfortunately I also managed to smash the ceramic top on ours earlier in the trip and so now we don't have it. Wife is really ticked off with me about that as I was the idiot that smashed it.
I know Ron a little - talked to him before we committed to our truck.
