Its Alive
nightfoam
Thanks, Its taking a while to get it the way I want it set up. Trying to keep it simple.
I think when you started unbolting the body from the frame is when things might have become no longer simple...
Looks AMAZING. I saw on your jkowners thread you're planning on being at EJS, I will likely be there too, hopefully we can connect, I wouldn't mind getting a closer look at that thing
dsy
Spent a little time with the rattle can again. This time after seeing pics of the interior of Lower Forty. Thought it looked sharp with the center stack color matched so here is my imitation. :)
dsy
Hemi Snorkel installed
Well almost. I have the snorkel coming next week but I got the AEV Hemi
snorkel kit installed. Like their Hemi swap kit the snorkel kit is awesome.
Everything fits and looks like it came that way from the factory.
For the 5.7 the snorkel box kit comes with the brackets for the stock bottom
part of the air box. You need to reuse the rubber grommets from the stock
battery / airbox tray that the post on the bottom of the airbox go into,
so don’t pitch those if your doing a hemi swap.
The kit also comes with a permanent K&N air filter that fits into the stock airbox.
The last and most important part, The new airbox lid designed for the AEV hemi kit.
With the 5.7 Hemi you also have to purchase a ERG block off kit that is pretty much
self explanatory.
One of the nice things about this snorkel kit is it makes access to the Alternator and
the lower radiator hose very easy. Pop the box out and everything is wide open now. :smiley_drive:
Doug
Jeepthreat
awesome build!
Even your coolant is clean!
Good work - love the rolling chassis shots always.
dual battery setup and snorkel too. awesome
Clemtiger84
