MBPXJ
Not really sure what to call that ugly, discolored, pealing plastic pieces that run along the bottom of the Cherokee doors? But today I decided to remove them. I started with the usual Goo Gone, waaaay to much elbow work. Then I stepped it up to the power washer; a little better but still took waaaay to long and would not get that last little bit of sticky residue.
Then came in the heat gun :wings:. This was the ticket. First after pulling off the plastic by hand, spray the residual dirt that is bound to be hidden behind the plastic runner. Using the heat gun about 1 inch to 1/2 inch away from the sticky foam/guu let the foam bubble and turn a little brown and continue down the door panel for about 5 inches. Then with wet rag push against the door panel guu repeatedly in the same direction letting the guu roll upon itself. I just kept going with it until it stopped rolling then went back to address the smaller guu left over.
It does take some elbow grease but those ugly plastic runners have been bugging me for a couple years and was well worth the effort.
Here are some photos.
The Heat Gun
Plastic Runner Removed
Guu Balling Up
Progress
Finished Product
Hope this helps!
The Heat Gun
Guu Balling Up
Progress
Finished Product
Hope this helps!
