Kitchen Configurations:
Scott not sure what you currently have just inside the tial gate but how about one of those tuffy jeep pull out drawer addemblies. They have good gasket to keep out dust, and should hold all your stoves utensils etc. Plus you could install a sheet of cutting board to the inside of your tail gate to prepare food. This may be a beter set up for trips on the move since setting up kitchens can be an afair.
cruiseroutfit said:
Not a bad option for $130... stores small, takes just a few minutes to setup I presume?
I have not used their new version. My unit takes about 8-10 minutes to set up. the big issue is weight (about 60lbs.)
Wow, thats almost double the newer unit (35lbs). How do you like the provided bag?
I am not sure if it is the same bag now, but the one for my unit is a heavy canvas and has a shoulder strap and thick handles.
I always make sure the unit is really strapped down, as if it got loose, it would destroy everything around it. :gunt:
Thanks for the info.. I'm really interested in that unit, a quick call netted me a bunch of info, they are very helpful on the phone. Thanks for the lead. :jumping:
I have considered that option, but now with the water tank, I need the flexibility (I have a trunk the size of a Miata's now).
I will likely build a drop down platform off of the swing-out and then build in a slide out stove, etc. too.
Lots of great ideas here guys!
OutbacKamper said:
Thanks Chris for the heads-up. I always seem to have problems linking to webshots. Can anyone recommend a better free internet pic host site?
Expedition Portal? I can provide you with a subdomain and your own directories.
Yea I thought you were tight on space back there. You could always go back to useing a cargo basket on the roof. I know you concern is the added wieght up high, however I would imagine on long expeditions you are prudent and drive more conservatively. You could also use it for carring the lighter items such as first aid, recovery(minus chain of course), nonrefrigerated foods, etc. A couple of storm/pelican cases and you would be set. for security you could permanently mount them to the basket by using some u bolts to fasten them to the rack. You would of course have to drill holes in the bottom but it would make sure your boxes wouldn't get ripped off. I know the pelican cases have a pad lock hole in them if you were leaving the truck in a marginal area.
I'm sure you have already contemplated this but I thought I would throw it back out to you. I would think that a wider cargo rack then you had previously would make a big difference in ease of use. The mega warrior basket from yakima is a perfect fit for the roof of a double cab. It is exactly the size of the roof.This makes for easy access by standing on the slider, since you do not have to reach way in. Just another thought.
Right now my kitchen revolves around my Jetboil
http://thehowzone.com/how/Jetboil
We were conducting a winter survival training in the mountains with an overnight emergency bivy (sans tents) in 20 deg temps. It was great to put out my Jetboil and cook up some food and hot Mocca for my teammates.
You are not alone Ian... Everyone seems to be exceedingly happy with them. :luxhello:
LukeSkywalker515
