tdesanto
Side note:
What I like about the Lansky and Apex style of sharpeners, is: you can make double bevel edges, and you can create different edges for different types of cutting. And you can easily re-create a damaged edge.
You don't want the same edge angle on your chef's knife as you need on a pocket knife. Even the kitchen knives should have different edges: chef, utility, butcher, chopper, santoku, all need different edges. Unless you are skilled at controlling blade angles against the sticks, the Spyderco will not do this for you.
The only correction I'll make here: this isn't a "side note"; instead, it's the whole point of getting a flexible system. You state it perfectly though. The Edge Pro instructions even recommend double-bevel edges for certain blades and shows you how to do them.
Nice summary of critical features and benefits.
