Lance 815 Refrigerator upgrade...
The original Norcold N300.3 12V/120V/LP refrigerator that came in my 2008 Lance 815 has been an aggravation since I bought it from the original owner about 4 years ago. Not so much that it didn't work fairly well, but more that the limitations, efficiency and idiosyncracies of gas absorption refrigerators left a lot to be desired. On 12V, the unit draws about 11 amps and the duty cycle is pretty close to 100% on warm days if I want to keep things suitably cold for longer durations...about 3000Wh/day by my calculations.
First aggravation, I had to replace the cooling unit about 3 years ago due to returning from a trip and parking my rig on the sloped parking area where I store it when off the truck, though I level it when I take it off the truck. It was late and I didn't feel like unit off the truck or unloading the fridge, so I just left it on until the next afternoon. By then the cooling unit was trashed and I ended up replacing it myself with a rebuilt one at about 1/3 the price of a new fridge. That worked fine, but I've always been nervous about parking in unlevel areas, even for a short while. No one could tell me what the limits might be.
The other problem is that I only have one 20lb LP tank and originally only 1 100Ah FLA battery. The battery would be near dead in the morning after running the fridge and other minor loads overnight unless I switched to LP at night and while parked. As I'm often off-grid for several days at a time, that eats into my LP allowance for occasional hot water and cooking.
To cope with this situation, I bought a couple 100W Renogy Eclipse Panels and an MPPT controller...that helped, and I could run on LP during the day while I recharged the batteries and then switch to 12V overnight, but I didn't have enough power to run 12V full time. I could charge the batteries or run the fridge during the day, but not both. So, I bought 2 more panels and with those, I could run it off 12V full time for several days before having to crank up the generator and makeup the shortfall or switch over to LP and let the solar system catch up. That being that I was typically using 3000+ Wh/day and, on a good day, only putting back about 2200Wh via solar. All this was a PITA.
I had been thinking about switching over to a LiPo battery for a while and finally did at the beginning of the year. Adding the 100AH LiPo really helped buffer me for cloudy days, but it didn't fix the fact that I was using more than I could put back with solar...I still had to run the generator after 2 or 3 days to catch up.
I was reading the current build by DrivenToAdventure last week where there was mention of a refrigerator brand I'd not heard of before...Vitrifrigo. I did some research and discovered there is a 4.7 cu.ft. model that might fit the space I had available. It's compressor based and operates off 12V or 120V and only draws 45W, either on 12V or 120V...this translates to 3.75A when operated on 12V...an immediate 60% reduction in power when running...and that doesn't take into account any reduced duty cycle. I was de-AMP'd :)
I spoke to one of their dealers, Citimarine in Miami to confirm a few things and they suggested that I speak directly to the USA distributor that was also in the S.FL area. Spoke to Dana with Vitrifrigo and he was kind enough to double check the actual unit dimensions on a unit they had there. Looks like it would fit with a little room to spare, though I'd have to enlarge the opening about 1/2" in height and about 3/4" in width...and there was space to do both. Ordered the unit on Monday the 8th and to my surprise, FedEx ground delivered it on Friday morning the 12th...by 7pm Saturday evening, it was in and running! Freight was included, btw.
My biggest concern in all this was whether or not I'd have to remove the door frame to get the old unit out and the new unit in the camper. I had to take some pieces off the back of the old unit and remove the door to the wet bath, as it protruded just enough to keep the old unit from clearing between the bath door and the seating across from it. The new unit had about 1/4" to spare.
Unlike the Norcold, which really takes a day to cool down if it's been off, the Vitrifrigo was down below 40F in less than an hour...and I went from 2.7 cu. ft. to 4.2 cu. ft. with a real freezer section.
This afternoon I inserted a power meter in the 12V power feed to the unit and my preliminary power measurements are in agreement with the factory spec's...running current draw is 3.72 amps for about 48W at 12.6V. Quiescent current is less than .01 A. I had let the unit run overnight, so it's certainly thermally stabilized...around 35F at the current thermostat setting. The big gain is going to come from greatly reduced duty cycle. Temp today was in the low 70's, so not near a worst case test, but I recorded about 13Wh/hour with the unit running for around 4 minutes every 15 minutes. This is without me opening the door, so likely typical of overnight performance. That comes to around 312Wh/day instead of 3000Wh/day with the Norcold. Even at a conservative 500Wh/day, I've reduced my power needs by 83%...that's huge!
I can't speak to longevity, but I'm impressed with the build quality of the unit, both inside and out. Insulation seems far superior to that of the older unit. I'll be taking off on a trip at the end of the month and will be monitoring the performance over a typical usage cycle. Will update with any useful info.
Cheers!
Old removed...
Fridge Install by Tom Stites, on Flickr
A close fit...
In, but bottom trim to install...
[url=https://flic.kr/p/Nidxye] Fridge Install by Tom Stites, on Flickr[/URL]
oldnslow
I had similar experiences with the original fridge in a Lance 845. I replaced it with a NovaKool unit 3 years ago and have been very happy with it. It is similar to a Vitrifigo. The extra space is really nice and it regulates temperature far better than the old unit did.
I think you will be very happy with yours.
Regcabguy
Oil eater.
My Dometic is going on 18 yrs. No circuit board,just knobs. I always carry leveling blocks so leveling isn't an issue. LP is super efficient,AC a bit less but the 12v on the road absolutely sucks on mine.
Looks like a good unit!
c.traveler2
LivingDaDream, nice conversion to a compressor refrigerator, I did the same back in 2013 after I got tried enough of my Norcold 300.3 failing too many times. I went with a Dometic CR1110 (3.8 cu.ft. with a freezer) myself plus I did addition upgrade of my camper wiring and an additional battery.
Dometic
Supporting Sponsor / Approved Vendor
Post some pictures of it! 18 years sure is a long time!
A quick update...very pleased with the performance of this unit so far. I've taken 4 trips of a week or more and though I wasn't boondocking the whole time, it's been great to have the extra space and the ability to maintain a more consistent temp in the refrigerator/freezer...not to mention not having to worry about parking on level ground if I want to stop somewhere for some sleep.
Cheers!
Ari3sgr3gg0
I use an older 12v RV fridge, it's compressor driven but uses a special board to get the right voltage for the compressor. A compressor driven fridge is many ways leaps and bounds ahead of the absorption fridges. More room inside and much less electrical hungry :)
ViperNL
Still going strong? Looking to upgrade our Norcold N306 in our ‘14 Lance 825. For some reason this thing is 2 Cu Ft larger but still roughly the same dimensions. Plus I hate having to deal with these propane fridges.
Yes it is, no issues whatsoever...I can whole-heartedly recommend it. I think the main gain in Cu Ft is the greater depth in all but the lower area where the compressor, power supply and fan are located...and not losing space at the top behind the Norcold control panel. It's a toss up between the fridge and going with a Lithium battery for best money spent on my camper since I've owned it. In fact, a week ago I replaced the 100AH Battleborn battery with a 280AH DIY system that I put together myself. Now I've got even more buffer if I end up with more than 3-4 cloudy days in a row. The new battery system fits in the same battery compartment as the BB or a lead-acid battery, but gives over 2X the capacity. I've got the BMS set conservatively for around 240AH to start, but can very easily reprogram the BMS to charge to a higher level and discharge to a lower level and get a full 280AH, though I don't really see the need for that with my current usage.
huntingstill
Cheers!
Hi LivinDaDream, I have an 07 815 and am wondering if your Vitrifrigo is the model C115IBD4-F-1?
Regcabguy
Oil eater.
Cheers!
Old removed...
A close fit...
Does the hum interrupt your sleep? I can't handle hotel room fridges.
I'm probably a bad judge of the unit being a problem for a light sleeper...I spent many years traveling 60-80 days a year and hotel air conditioners with their cycling on and off, rattles, etc., never really bothered me. That said, I'd judge my particular unit to be pretty quiet and I don't really think about it. The cavity that it mounts in has some insulation on the sides, so that helps a little and the compressor is on rubber mounts...seems the cooling fan makes more noise than the compressor. I had to shim the rear support base of the refrigerator and used some closed cell foam material...I suppose that helps with any vibration transmission to the camper body. I have the means to make a high quality recording of the sound it makes and perhaps I'll do that, though not sure how I'd reference it to another sound level...maybe in relation to the fantastic fan on low at the rear of the camper?
Smudge12
