Land Rover Defender 110 SW 1993/94 "Endurance"
Loras BR
oonimog said:
Loras,
I attached a sheet that shows the specs of OME springs for Defenders. I've installed the heavy duty units on my truck and although I thought they were too firm when I first did the upgrade, I'm very happy with them now. The suspension articulates very well and they raised the truck a couple inches, which is what I wanted as I've installed 255/85's (BFG M/T that I'm also very pleased with).
Cheers
Oonimg,
Could you check the high of your 110?
I need the distance between the center of the axle and the inferior limit of the black part in the wheel arch. Front and rear.
The distance chassis - ground would be nice too. In the four corners.
Thanks.
