Thanks guys. I am running an auto transmission so the clutch pedal assembly is not important. The pedal for the hydro boost is though. I believe the whole pedal assembly with both brake and clutch pedal is one unit, is it not? I will probably need the rods that attach the cylinder to the pedal assembly and the push rod and housing too
The Vanco unit comes with the linkage that hooks to the pedal and everything else you will need. The only thing you need to do is move your existing pin to the upper hole and weld it in place as I mentioned. The pump needs to put out 1200-1500 psi. You can either modify your pump if it is in good shape or replace it with a new one. Here is a link on how to modify it:
http://westtexasoffroad.homestead.com/powersteering.html
They also sell them with the modification done already, but it is easy to do and cheaper to do it yourself. I hate to keep trashing Larry's thread, so maybe it would be best to start another one about this hydroboost modification?
