Latest on 270 Degree Awnings?
codename607
I'm looking to purchase an awning that is 270 degrees and has the option to have walls. Can someone point me in the right direction? All I can find are the ones without walls.
Maxcustody
Eezi awning bat 270
Sent from my SM-G920V using Tapatalk
JCTex
Maxcustody, I also have an EzziAwn, the Manta (largest ver.). Can you tell me how the side panels attach to the awning? I know there's a horizontal pole from the first vertical to the second; but how are the other sections so tight and straight?
Maxcustody
JC there are several sets of poles. You need to drill holes in the aluminum for it to attach. It is a pretty easy install. Just measure and be sure it is correct before drilling............
rino
Supporting Sponsor - OK4WD
Alu Cab Shadow Awning, pole less for quick stops or you can drop the poles and install the wall kit which has windows with bug screen and doors.
Also this unique design covers your complete tailgate area without an angle, giving you more room where it matters most!
Raul B
That's nice.
Sent from my SM-G930T using Tapatalk
BentBomber
www.bomberproducts.com
The Alu-cab awnings are very very nice. I'm a fan. That being said I have a Foxwing and am very happy with it. Sides zip on and there are a ton of options. I'l agree that the South African offerings are very well made and designed, and also nearly twice the cost. It's all a matter of priority and how and how often you'll use it.
codename607
Thanks for all of the feedback. I'm leaning more towards the Foxwing only because I can get it at a decent discount.
WonaWarrior
