R_Lefebvre
So, my 3 Amigos problem seems to be migrating. At first it was a bad ground. I cleaned the one behind the headlight, but the lights are still on. Now I'm getting something about a bad signal from the front right hub, bad signal, and then something about that side being shorted to ground.
The tech told me I probably have a leaking hub, and the oil is messing up that sensor. That's not surprising, because I had already started to notice that the steering knuckle on the front right was wet with oil on the outside.
I remember reading something about it could be an o-ring that might be able to be replaced, rather than it necessarily needing a new wheel bearing/hub altogether? Anybody have details on this?
