Leaky 2003 1st Gen 17" Tundra / Sequoia alloy rim
jeffjeeptj
I left the spare under the Sequoia for too long. Spare had no pressure, so I filled it up to 50 psi. Leaks almost 360 degrees around the bead, and a portion of the rim edge has paint flaked off with badly corroded aluminum material. I lived in salt country for 2 winters. Tire has no dry rot/ cracking. Friend at work said he had this problem 2 years ago.
In looking for the lowest cost replacement spare, will 16" factory tundra steel wheels clear the 2003 sequoia bigger brakes. I bought the 2003 Sequoia new with the 17" rims. Also, will the 6 lug 2007 to 2014 FJ 17" steel rims fit, so i can keep the 17" tires? Info shows FJ offset is 14mm, the Sequoia offset is 15mm. 0.039" should not mean much.
Thanks in advance
calicamper
I found an Ebay wheel recycler to be pretty good source for random wheels. My wife destroyed a wheel on her 2016 Fusion two months after we bought the car. Ford wanted $700! Ebay guy wanted $200. He was fast and the wheel was prestine. Id go that route again my self. My sequoia wheels were cheap.
Deleman
