Leaving cooler at site on hot day
1000arms
... A couple of cheap but well insulating comforters can be used to insulate a cooler in a car. Surround the top, bottom and sides of the cooler. Use other bedding to sleep with.
... I have a naive question about coolers: Do you add insulation around the cooler to keep the cold in or to keep the cold out, or both? ...
Insulation is used to reduce the flow of heat (or electricity/sound/...). Insulated walls/roof/floor help keep the heat in a heated house during the winter, and help keep the heat out of an air-conditioned house in the summer.
By using enough non-sleeping comforters/blankets/sleeping-bags to insulate the top/bottom/sides of a cooler, one can keep a cooler cool (keep the heat from warming it up) even in an enclosed vehicle sitting in the sun. Eventually more ice/dry-ice will be needed, but one can greatly extend the life of the ice this way.
For the best results, use a great cooler, multiple layers of non-sleeping comforters/blankets/sleeping-bags, and keep as much heat out of your vehicle as possible. Park in the shade if possible, use reflective car window sunshades, and consider creating a "false roof" to shade your roof from the sun.
mbauerus1
