Lift considerations
spressomon
NorCalSam said:
Dan I can't find anything on these compression adjusters.
Sam,
They show/list them here. Sam at Samco here in Reno was able, since I already owned the shocks with remotes to order from Fox just the remote tops with the adjusters...which he installed during the last round of mods. Otherwise methinks the guys at offroadwarehouse would be able to hook someone up with the appropriate goods as long as you gave them the shock compressed/extended measurements you were after...
http://www.offroadwarehouse.com/products/sfID1/12/sfID2/24/sfID3/26/productID/98
Pskhaat
2005 Expedition Trophy Champion
850J and 864s and then add 1" spacers after you want some more. You should also get your panhard arms lengthened slightly. The OME bushings IMO are enough of caster correction but Slee's caster plates work great too. Keep it simple.
