LightForce Genesis
FlyingWen
The LightForce Genesis lights are arriving the middle to end of November!!!
Sierra Expeditions is accepting pre-orders
The Genesis lights are 210mm/ 8.5". They are available in either a Cornering Beam or a Spot Beam, 12V or 24V and also HID or Halogen. Right now, the lights are being sold Individually, but will most likely be available in a twin pack down the road.
Features:
* HID Bulb optionsthat give you more
* 15% Larger Reflector Surface Area
* Hard-Coated Polycarb lens and filter
* Less then half the weight of our rivals
* Sculptured Alloy Bezel
* Mil Spec Gore-Tex Breather (protects against moisture)
* Unique Mounting Position Options (4 mounting options)
* Anti-Theft Kit Options
* Filters available in: Clear, Yellow, Amber, Crystal Blue, and Opaque Black
* Filters available in above colors in Spread or Spot Filters
spressomon
The last I heard they were still in final phase of design/manufacturing tweaks. Something to do with the new style bezel. And January/February was the new ETA for US.
flyingwil
lostworldexpedition said:
Are the Genesis lights available? Any feedback from the first takers?
Thanks...
The Genesis lights are still not in yet. The batch that was to be sent over had an issue with the filter clips. The coating that they use to cover the filters to make them scratch resistant was overbaked on, and was causing the filter clips to break. This was discovered the day the container was supposed to be shipped to the US and the're now in the process of making a new batch and applying the new filter to all the lights with the faulty filters. As soon as they are done they'll be on the way Unknown ETA at this point. There is a ton of filters in the trash some where!
JCCB1998
